Mahatma_Andy
Cluster hidden controls counter
Status: Declined
It would be nice to have a hidden controls counter for clusters in the lower left corner. It would also be nice to show them by context menu entry.
3 Comments
Knight of NI
Hi Mahatma,
- you can set the cluster to show all elements, you can even set it to sort them horizontally/vertically
- the context help already shows all cluster elements
- in the block diagram you can minimize cluster constants to icons
Why do you need your proposed "hidden element" counter?
Mahatma_Andy
It is the same with the case element. You can see at first sight if the ignore lower or upper case property is set.
When you replace a modern cluster with a system one the elements are gone and you don't see wether there was a hidden control or not.
Jeff-P
NI Employee (retired)
Status changed to: Declined
