User | Kudos |
12 | |
11 | |
5 | |
2 | |
2 |
The installer build spec dialog should analyze the components being installed and suggest what additional installers will be needed to allow the EXE (or what ever else is being installed) to function on the target machine.
Also, the 'Additional Installers' catagory screen should have detailed help explaining what each installer is for and why you might want to include it. Just looking at the names is not obvious enough. A good example are the following installer from the list:
LV Web Services
NI LV Web Services Runtime
NI LabVIEW Run-Time Engine Web Server
NI LabVIEW Web Server
Can you tell me which one(s) of these is needed to support the RESTful web services on a target machine? I cannot find this documented anywhere and when I called NI application support they could not either.
