In Diagram Disable Structure, if there is an option provides "Selector Terminal" that could help to control programmatically. This could be optional selection in RCM (Right Context Menu).
Connecting Enable/Disable as Constant/Control to Case Structure would not do all purpose as the functionally of Diagram Disable Structure Enable/Disable individual does.
Diagram Disable Structure have unique behaviour if this Selector Terminal is given as optional that will add even more vale to the same.
As programmer myself felt that why do this be controllable, because while developing big codes we use to much of diagram disable structure , when we are suppose to change to Enable or Disable, I has to search for around my code. If this has controllable option that help to do my work even more efficient specially while testing code.
Declined for reasons listed here: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Diagram-Disable-Structure-with-Selector-Terminal-as-op...
