GregFreeman
Drag and drop control into even structure with option to create new event
Status: Declined
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
It's sometimes bothersome to have to go create an event then go get your control and drag it in to that new event case. I would like to be able to drag and drop a control into the event structure in any case and have the option to either place it in the case you have currently selected, or pop up the dialog to create a new event case, then have it dropped in that new case automagically.
3 Comments
GregFreeman
Trusted Enthusiast
On second thought, this may be annoying to have a pop up every time you place a control. Maybe if the case exists already don't ask, and if you have multiple controls you are dragging in don't ask. Suggestions are appreciated.
stbe
I'd rather press a hot key - eg. Shift or Alt to trigger the "create even case" behavior ...
_________________________
CLA
Darren
Proven Zealot
Status changed to: Declined
