Has this ever happened to your application?
Well, it happened to me many times. I never figured out when this happens and when it doesn't, but I do know of a certain way to disable it - add the line HideRootWindow=TRUE to the application's INI file.
The problem with that solution is that when you build a new EXE, LV creates a new INI file which overrides the old one, unless you explicitly create your own INI file and tell LV to use it.
So, the solution to this is simple and this is the idea - LV should add the line HideRootWindow=TRUE to the application's INI file by default. Problem solved. Alternatively, maybe the whole root window thing is not needed anymore and NI can simply get rid of it.
