Simply put, you should be able to put a URL hyperlink in a floating comment to link out to some site.
Imagine being able to add a hyperlink to the mathematical description of a VI that you used. Perhaps you have an internal server of IP Documentation. You could add a hyperlink to that in depth information directly in your VI. Perhaps you want to put your logo along with a link to your website at the top level of your source code. Whatever the reason, you need to be able to add a normal comment to the block diagram and populate that comment with text and hyperlinks.
As a extension, this new comment field could even take simple html tags for more formatting, embedding images, or maybe even an embedded video.
Available in LabVIEW 2015 and later
