jj2
In range and coerce should have additional polymorphic functionality like accept tolerance
Status: New
Should be able to specify tolerance instead of just upper and lower limits. This de clutters the application block diagram when you are checking for a value within certain limits.
 . Upper limit becomes : x+ tolerance, Lower Limite becomes : x - tolerance when using tolerance instance of the polymorphic vi.
For even higher level functionality , specify units of tolerance : absolute, percent(1e-2), parts per million (1e-6), parts per billion (1e-9)
2 Comments
crossrulz
Knight of NI
Similar idea: "Almost Equal" functions for Float comparisons
GCentral
PaulG.
Both ideas are great. Kudos to both.
PaulG.
LabVIEW versions 5.0 - 2023
“All programmers are optimists”
― Frederick P. Brooks Jr.
