When I want to insert a VI into a wire, I often have to navigate a long way in the palette until I reach the VI I want to use. The same is true when I replace a VI. Both palettes have a special top level with direct access to palettes LabVIEW thinks I might use. But this is often different from what I want. This is why I ask for including the favorite palette menu in this special top level menu. Then I can keep a short navigation to whatever I want to. (Of course it is only one level shorter tahn before, but the entry point to favorites is much more prominent.)
