altenbach
Installer Builder option to require SSE2 support
Status: New
In newer LabVIEW versions, we can build executables that require SSE2 support an this option is even the default.
If we built an installer, we can select many other system requirements, such as the minimal OS version or the presence of the LabVIEW development system.  However, there is no option to prevent installation if the CPU does not support SSE2.
This means that an application that requires SSE2 support will install just fine on a non-SSE2 system and will fail only once we try to actually run.
I suggest to add a system requirement option to the installer builder so the application will not install if the hardware is not suitable. It should maybe even be enabled by default.
Here's how it could look like.
3 Comments
Mads
Or - make it possible to build and ship two versions automatically, with and without the SSE2 requirement, and make the installer figure out which one to install...That way we can almost forget the whole thing, and just remove the non-SSE2-version if we know that the application will in fact need it to perform adequately.
Yamaeda
Proven Zealot
I agree in principle. However i dont like having an extra option which'd allow a non SSE program to require it from the CPU or the opposite. If SSE is enabled in the compile it should be required on the target.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Mads
If the application is set to be optimized with SSE2, then the installer should refuse to install on CPUs without such support - period. No need for any new input in the app builder.
 If a feature like the one I suggested above was implemented (to allow us to compile with AND without SSE2, and let the installer decide which one to install), then a choice to require it would not make sense either.
So in a way I agree with you Yamaeda, but the core of the idea is still good.
