hecmar.arreola
Merge Shared Variable Refnum with Shared Variable Control
Status: Declined
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
This is an offshoot from this thread in the forum: http://forums.ni.com/t5/LabVIEW/Difference-between-Shared-Variable-Refnum-and-Control/m-p/2378020
The Shared Variable Refnum and Shared Variable Control (for the DSC Module) is essentially the same concept and I think that merging the two should be considered.  The recommendation from Daniel REDS in the NI Forum thread was that I post an idea to make a silver control of the Shared Variable Refnum.  I would say that would be nice, but I think that the two controls being merged into one would be more ideal since they both contain essentially the same Variable browser and conceptually are referring to the same thing.
2 Comments
Ajay_MV
Hey,
Since you posted, I guess you can answer my doubt about merging shared variable.  Could you look into this forum thread?
Ajay.
Ajay MV
Darren
Proven Zealot
Status changed to: Declined
