Spectre_Dave
Move Stacked Sequences from the Palette
Status: Completed
Implemented in LabVIEW 2014
There has been a lot of discussion on this but no LabVIEW Idea (that I was able to find). Please move the Stacked Sequences from the Programming Palette to a "retro" or "classic" palette. This is dissuade novices from overusing them
Previous wording:
Retain them for legacy code but please remove them from the Programming Palette
Lets vote this in and get rid of Stacked Sequences forever.
I would go so far as to release a patch to remove them from all Installed LabVIEW Versions!
Message Edited by Laura F. on 09-30-2009 03:49 PM
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
26 Comments
Knight of NI
While I don't use them as a general rule, I would still be strongly opposed to this idea. What are you going to dislike next? Flat sequence structures? Global variables?
There are NO "evil" constructs in programming. Only abusive programmers.
johnsold
Knight of NI
I might support moving them (and flat sequences) to an "Advanced" subpalette, but they should not be removed.
Putting them in an Advanced palette will likely keep many of the LV beginners from using them.  By the time someone reaches the level where they are looking for advanced structures and functions, they are less likely to abuse them.
Lynn
Spectre_Dave
I disagrre with the "Advanced" subPalette but I would okay putting them in a "Retro" subPallette.
CLA
Jim_Kring
Trusted Enthusiast
crelf
Trusted Enthusiast
Yeah - if you changed this idea to "move" instead of "remove" I'd think more seriously about giving it kudos.
: "There are NO "evil" constructs in programming. Only abusive programmers." <- love it!  I'll kudos that 🙂
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
Spectre_Dave
I asked the Moderator to change the name to move.
I am surprised that so many people are passionate about keeping Stacked Sequences.  I learned on stacked sequences (LV 1.2) because that was all we had but I was an early adopter of the LTR State Machine architecture (LV v3.x?) and I have not looked back.
The only place I use flat sequences is in my FPGA code.
CLA
Intaris
Proven Zealot
I for one am simply pragmatic.
Sometimes it's easier to use a Stacked Sequence than to do it any other way.  Given the choice between deadlines and small design faux-pas, 9 out of 10 customers will choose deadline.
Spectre_Dave
I have fully accepted and assimilated  state machines that I NEVER think about stacked sequences.  I simple drop a while loop, add case a structure, add shift registers and put code in the cases - bingo I have a functional state machine.
Now for larger applications I use a QSM but there I have created templates and a polymorphic Queue handler to facilitate reuse.
I can code a simple SM as fast and reliably as you can code a stacked sequence.
CLA
Laura F.
I've updated the title as requested.
Laura
crelf
Trusted Enthusiast
I see you updated the title, but that's not really what I meant (my fault, I should have been more clear).  What I meant was that I would not consider kudos'ing an idea that removed the structure, but I would consider kudos'ing an idea that moved it from the sutrctures palette to somewhere buried deeper.  You'd need to change the idea verbiage significantly for that - if that's what you want to do, of course.
