Timed structures require a priority for scheduling. Default priority level is 100 for each structure.
If that priority is not changed (one dedicated priority level per structure) it could lead to unexpected behavior like hangs.
Therefore i propose a new test for the VI Analyzer which tests for unique (static) priority levels in timed structures. If there are priority levels shared among several structures, the test shall fail.
The test shall also work within a whole project, so it shall not only check this within single VIs.
Norbert
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
