CaseyLamers1
New format for "New Vi for Override"
Status: Declined
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
I frequently use the "New VI for Override" feature in my projects.  Problem is, I always have to add a case structure with an error case and I rarely use the call parent method.  I'd like to see something like the template for "New VI for Dynamic Dispatch" but with the call to the parent in the case structure.
Casey
Casey Lamers
Phoenix, LLC
casey.lamers@phoenixwi.com
CLA, LabVIEW Champion
Check Out the Software Engineering Processes, Architecture, and Design track at NIWeek. 2018 I guarantee you will learn things you can use daily! I will be presenting!
4 Comments
CaseyLamers1
Here is an example image...
Casey Lamers
Phoenix, LLC
dthor
Correct me if I'm wrong, but can't you edit the template used by "New VI for Override" so that it has the case structure? I know you can edit the Dynamic Dispatch template, but I've never tried with Override. In fact, I don't think I've ever even used "New VI for Override" so heck I'm not even sure it *has* a template.
Mr.Mike
NI Employee (retired)
dthor, there is no template for New VI for Override (as far as I know).
-- Mike
Darren
Proven Zealot
Status changed to: Declined
