Darin.K
Numeric conversions should accept boolean inputs
Status: New
My LV intellisense prototype has been telling me something very interesting recently.  When I use it on a Boolean to 0,1 node, it really, really thinks I want to put in an I32 numeric conversion.  Looking deeper, almost everytime I forgo the I32 conversion I am utilizing an implicit coercion.  What I have not wanted, probably since the LV4 days is an I16.
The following suggestion is a marginal improvement:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Change-Output-Representation-on-quot-Boolean-to-0-1-qu...
I like output configuration myself, but it can be easily hidden from beginners, and not-quite-beginners alike:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-Output-Configuration-for-the-Compound-Arithmetic...
And teaching people about it is not enough sometimes: Smiley Surprised
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Output-Configuration-for-Add-Multiply-Array-Elements/i...
So I suggest skipping the middle man and allowing the numeric conversion functions to accept booleans directly.  So simple even a text programmer can do it.
14 Comments
tomlawton
Nice idea... Apart from the use of "Show terminals as icons".. 😉
Jim_Kring
Trusted Enthusiast
true convert to one?
coerced by Darin's logic,
this gets a kudo.
altenbach
Knight of NI
We could take it even a small step further and allow simple arithmetic operations between numerics and booleans, e.g. "N + boolean" would be either N or N+1. "N * boolean" would be either zero or N, etc. (probably should show a coercion dot, but still....)
kegghead
I'd argue it's not the job of the explicit numeric conversions to do this. Who's to say what a True value is (other than nonzero in LabVIEW's case)? I'd rather see the behavior of the Boolean To 0,1 primitive changed based on my comment I just posted on Jack's idea-- where the output just automatically adapts to the downstream node.
altenbach
Knight of NI
> Who's to say what a True value is ...
Well, in this case the behavior can be fully documented in a small sentence. No need to get philosophical. 😉
(Other languages are similar here, look e.g. at the bottom of this python documentation)
Implementing this idea would make the "boolean to 0,1" primitive completely obsolete, simplifying the palettes. I am all for it.
X.
Trusted Enthusiast
Trusted Enthusiast
Heck, I'd say connect the boolean to the numeric DIRECTLY and throw a coercion dot! Your suggestion is so 2013...
After all, you can connect an error cluster to a boolean primitive:
But an LV Intellisense prototype? That sounds fun.
Darin.K
Trusted Enthusiast
Do not want to derail the discussion, but it is very interesting.  I construct an edge weighted directed graph containing the primitives I have used in my VIs.  The edge weighting is probability that I have connected the two together.  I was looking at some stats and noticed a heavy edge weighting between the Boolean to 0,1 and the To I32 node.
By far the coolest effect is that I can actually think two moves ahead, not only can I sometimes predict what I want to place next, but even the node after that.  As I have described elsewhere, I have replaced QD with a graphical version which I call SpeedDrop (how original).  When I put it in hopscotch mode and select a node it autopopulates the results window with the nodes most likely to be connected to it.  I need a few tweaks to get the realtime performance up to my liking and it would need training VIs from a variety of users to make it generally useful.
It also tells me that Obtain Queue is often followed directly by Enqueue Element.
altenbach
Knight of NI
I made a seperate idea for this to keep things organized.
ouadji
Trusted Enthusiast
You often have very good ideas Darin, but I don't like this one.
how to say ... with my poor english ... hummm ...
i will try to do my best,
This idea is certainly convenient in terms of programming
but this idea removes the "primary/original" meaning of the boolean.
I think this idea will make the BD least understandable at first glance,
and could bring confusion.
In my case, I prefer to keep a conversion function between Boolean and munéric.
Darin.K
Trusted Enthusiast
We shall have to agree to disagree.  I find it readable and it gives me code that runs twice as fast in half of the time.
