elset191
Or (and And) Array Elements should work on numeric arrays
Status: New
When you or two numeric numbers it does a bitwise or.  The same should happen when using Or Array Elements, but it is not supported for numeric arrays. I see no reason why it shouldn't work just the same?
Tim Elsey
Certified LabVIEW Architect
3 Comments
gb119
I think the operation should be something like this:
Gavin Burnell
Condensed Matter Physics Group, University of Leeds, UK
http://www.stoner.leeds.ac.uk/
wiebe@CARYA
Knight of NI
This does the same:
Just for the record, this thread: "XOR Array elements" is related, and suggests this post as a better solution. It would be great to have both: XOR Array elements, and have all boolean array operations adapt to numeric arrays as well.
Xor Array should do:
Only problem is creating a symbol, since propositional login has no universial exclusive disjunctive symbol. This would work:.
crossrulz
Knight of NI
I just ran into a perfect place for this enhancement: Combining Option Flags into a Single Option Value for Open VI Reference.  Related idea to this situation: Replace Numeric "options" with Ring on "Open VI Reference"
GCentral
