TiTou
Path control with auto-complete (similar to Terminal)
Status: New
When typing a path in the Terminal (Linux, Windows or macOS) hitting the table key does an auto-complete, this is extremely useful.
I wish the Path control and - let's dream - the path constant would behave the same.
It's probably only applicable to absolut path values.
I've made a QControl that does that, it's a bit basic but it does help, I might post it GitHub if there is interest.
Epictetus
Antoine Chalons
5 Comments
Christina_R
The problem I see is that the Tab key is already used to move focus around the controls on the panel.
Christina Rogers
Principal Product Owner, LabVIEW R&D
fefepeto_kb
Maybe the Ctrl+Down Arrow could be used to navigate "into" the path control for using the tab autofill.
To further enhance the user experience a small indicator could appear at the edge of the control/constant to indicate the autofill mode.
And, to be backward compatible this autofill feature could be toggled as a global option, maybe per user once that feature is implemented, and its default shall be off.
TiTou
Trusted Enthusiast
@Christina_R
I see, then do the auto-complete only if the path control has the "skip this control when tabbing" enabled
Epictetus
Antoine Chalons
Christina_R
Removing a control from the tab order (i.e., skip when tabbing) has severe consequences on the usability and accessibility of a UI.
Entering a "mode" for the path control (e.g., Ctrl+Down Arrow) seems feasible, but I think it would be hard to make that mode easily discoverable.
Christina Rogers
wiebe@CARYA
Knight of NI
The path could go into autocomplete mode after typing anything.
Enter or escape could bring it back to tab order mode.
Still not ideal, but maybe a compromise.
