Keith_Ward
Propert Node To Show Current LabVIEW VI Error Listing
Status: New
Consider adding a property node that will return the current error listing of a VI or all VIs.  This wuld provide the same information a clickingthe run arrow on a broken VI.  This information would be of great benefit when programmatically analyzing the current state of a project or set of VIs to determine the root cause of why something is not executable.  Often there is one VI that is actually broken but is called by many other VIs that also appear broken but actually do not need anything fixed directly.  By having the error information, the root cause could be determined without a need for opening all of the other VIs.
3 Comments
tst
Knight of NI Knight of NI
Knight of NI
You don't need to open all VIs - the VIs which are actully broken are at the top of the error list and are marked with red Xs.
___________________
Try to take over the world!
Keith_Ward
That is correct, but the information is still not available programmatically which is the actual reason for the feature request.
crossrulz
Knight of NI
So you're looking for a new scripting property or invoke node?  I'm debating how much I would use this.  I need to think a little more about this one before giving Kudos.
GCentral
