I wanted to use a property node in an application today. I happened to have the Help context up and it showed "Run-Time Engine: No". But I could easily have missed that and not discovered the issue until much later, after building a lot of code and wasting time.
If the node had an obvious indication as soon as you put it on the block diagram - for example, a different color - that would help a lot and potentially save a lot of headache.
