NI has a private method for returning the hWnd of a VI but there is no "publicly" available method for this. The private method is already shared around forums and used extensively as interacting with the Win32 APIs is a common need for advanced UIs. The appearance configs for VIs only work relative to other VIs and trying to develop LabVIEW based applications that are used alongside other applications presents many roadblocks, even with other NI software such as TestStand. (TestStand has an API method for getting the hWnd!)
The other method commonly used is to also use the Win32 FindWindow call however this presents issues if there are multiple windows with the same captions (easy enough with Cloned VIs) and is not a robust approach.
