Jim_Kring
Replacing a Boolean operator with a Compound Arithemetic node should not change the operator
Status: Duplicate
I'm not sure if this is a bug report or a feature request, but I think it should be fixed/implemented, all the same 🙂
If you right-click on a Boolean funtion (And, Or, Exclusive Or, Not, etc.) and replace with a Compoint Arithmetic (CA) function, the CA function is always set to the "Or" configuration.  I would expect it to be smart and put the CA node into a configuration (including negation/inversion dots) that is equivalent to the Boolean function that it replaces.
3 Comments
JackDunaway
Trusted Enthusiast
Todd S.
NI Employee (retired)
Status changed to: Duplicate
Todd S.
LabVIEW Community Manager
Mr.Mike
I'd like to point out that the original idea has been moved to In Development.
-- Mike
