PROBLEM: When I start typing after double click the text changes MY BLOCK DIAGRAM! It hides elements, moves structures =(, but there is often a lot of space, that is intended for this comment
IDEA:
Resize the text, when double click, that inserted it, has not finished yet!
The text is inserted after the second Mouse _down_. Text behavior is Size to text. If the mouse button is released, the user can type a long line.
Proposed:
1) If user moves mouse with button pressed, the text resizes accordingly and stops resizing after mouse up.- Double click+move finished, text area has focus and ready for typing.
Or 2) Allow resize of the text area before (or while) typing in it - make sure the text doe not loose focus.
A few facts:
1) You should use free text to comment the block diagram.
2) Some LabVIEW users are not satisfied with its default size behavior:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Size-Vertically-To-Text/idi-p/1530678
Above ideas do not handle my PROBLEM:
Here are some ways to handle the problem with drawbacks:
1) Type one word. Resize comment (Autoremove Size to text). Back to typing --- Too many actions
2) Set text width by starting new lines. --- Will be hard to change width later
3) Scroll away. Type. Resize. Move to where it is needed. --- Brrr
4) My idea - modify LabVIEW 😃
Alexander
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
