User | Kudos |
5 | |
3 | |
2 | |
2 | |
2 |
I couldn't find a similar topic so sorry if it's already been asked 🙂
When adding an VI into a loop, container or select case, I do always trying to reverse-wire the inputs like the error input.
Unfortunately, LV will not recognize the datatype, if you connect an input from the input to somewhere else.
It's always needed to create the element (constant, front panel element) inside of the loop, move it out, and reconnect.
So it'd be great if you could simply connect the wire to the loop entry and then create there the element.
