dambored
Reverse of "Index & Bundle Cluster Array"
When you have several arrays of the same size and you need to sort them one can use the "Index & Bundle Cluster Array", use the "Sort 1D Array", the put down a for loop and then unbundle to get the arrays back to arrays.  It would be nice to have the reverse capability of "Index & Bundle Cluster Array" to make the array of clusters back to a group of arrays.  In my testing the  "Index & Bundle Cluster Array" was 5 times faster than a For loop and Bundle.  I would assume that the reverse could also be much faster.
6 Comments
RavensFan
Knight of NI
Did you happen to search the idea board before posting this idea?
Altenbach already suggested it here.  It actually has almost an identical tite to yours.  Please go kudo his post.
dambored
I did a search and got nothing.  Your link is broken.
RavensFan
Knight of NI
dambored
The "&" screwed up the search.  I guess I am to used to searching on Google.
RavensFan
Knight of NI
No problem.  I find it is very easy not to find things in a search that you really expect should show up.  I don't know what & does within the forums search function.
I just knew your idea sounded very familiar.  I just didn't happen to have any problems when I searched on the same terms.
Laura F.
