Cory_K
Select Array Data
Status: New
I think there should be some way to select data out of an array on the front panel.
Whe I mean by this, is that you can not click and highlight N x M number of cells, then copy and paste (into notepad, excel, etc).
It doesnt even work if you right click the array, then press 'data operations >> copy data', unless you stay in LabVIEW.
Cory K
2 Comments
Lavezza
I think it would be great if LV arrays could be edited more like Excel. Copy, paste, drag, delete, etc.
Technico
I'm also missing the possibility to paste the copied data from LabVIEW into EXCEL/Notepad/...
and maybe even the other way arround: import tab delimited text into an array/(string)table
