Daklu
Show dependencies in the 'Main Application Instance' project window
Status: Declined
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
Often on large projects rather than load the entire project I'll navigate to a .lvclass or .lvlib file and open it directly from the file system.  This loads the class into a 'Main Application Instance' project window; however, this project window is missing a key feature I use extensively--the dependencies listing.  Based on the VI Hierarchy view it appears that information is already in memory.  Sure would be nice to have it in the project window.
2 Comments
AristosQueue (NI)
NI Employee (retired)
Open an empty project before you double click on the file and you'll have the functionality you just requested.
Darren
Proven Zealot
Status changed to: Declined
