Jacc
Specify installer "..\volume" files - such as autorun.inf and autorun.ico
Status: Declined
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
I would like to be able to specify an autrorun.inf, an autorun.ico file and a copyright file in the Build properties for the LabView (or CVI) installer properties to be copied to the ..\Volume directory for the built installer. I can then simply build a DVD from the installer's ..\Volume directory and the DVD will autorun on insertion (if autorun is enabled). Of course, I can manually add these files to the DVD build, which I do, but if it is simple fix to the installer, well, Ithe next person who takes over my projects is less likely to make a mistake.
1 Comment
Darren
Proven Zealot
Status changed to: Declined
