It would be useful if LabVIEW offered the option to use an Error Collector Node inside structures.
The Error Collector Node would collect or capture any/all unhandled errors that occurred inside the structure that the node is part of. If one or more unhandled errors occurred, the Error Collector Node would output the first error that occurred (in chronological error). If no errors occurred, the node would output "No Error".
The following annotated screenshot shows how the Error Collector Node would help reduce the number of error wire segments and of Merge Errors nodes.
The following screenshot shows a second example. Notice that using the Error Collector Node would result in a significant reduction of block diagram items: 10 fewer wire segments and 1 fewer Merge Error Node. The reduction in block diagram items could be even larger if we consider that the other cases of the case structure (potentially dozens of cases) also benefit from the same Error Collector Node being placed on the border of the case structure.
The two screenshots above are examples created specifically for the purpose of posting this idea. The following screenshot is a real-world example (taken from production code) of a VI that could benefit from the Error Collector Node, which would remove the need for numerous error wire segments and Merge Error nodes.
Notes
- The Error Collector Node was prototyped as a hexagonal output tunnel in the screenshots above. I would, of course, be happy if a different glyph or shape is chosen to represent this new type of tunnel.
- Error Collector Node would essentially behave similarly to a localised Automatic Error Handling functionality. It would collect or capture any unhandled errors inside its area of responsibility (the structure), and would convert those errors back into "manually-handled" errors - i.e. errors than are passed downstream via an error wire.
- The Error Collector Node would be useful especially in situations where many code branches execute in parallel as it eliminates the need for lots of Merge Error nodes.
- The first two screenshots mention the words "approximately equivalent to". "Approximately" because, if multiple errors occur inside the structure, the Error Collector Node does not guarantee which of those errors are output in the same way that the Merge Errors node does. For example, in the first screenshot, if all three VIs (VI A, VI B, and VI C) experience an error, there is no guarantee as to which of those errors the Error Collector Node would output. The node would output the first error that occurred (in chronological order), so it would depend on which VI finished execution first. This could change from execution to execution, and from machine to machine. Whereas the right-hand-side version, which uses Merge Errors, would always output the error generated by VI A.
- This would usually not be an issue in practice. If more determinism is needed, the programmer could, of course, fall back on manually wiring the errors to define an exact error behaviour.
- It should be possible to add a maximum of one Error Collector Node to each structure: Flat Sequence Structures, Case Structures, For Loops, While Loops, etc.
- It would be useful if the Error Collector Node could be used outside of structures (directly on the outermost region of a block diagram). Again, enforcing a maximum of one Error Collector Node per outer block diagram would make sense. The Error Collector Node would execute after all other block diagram nodes and structures (would be the last thing to execute). The output of the Error Collector node could then be fed directly to an "Error Out" block diagram terminal. This would remove the need to wire most error wires inside the VI, while ensuring that no error goes uncaptured.
- If the Error Collector Node exist only as a structure output tunnel, and not as a stand-alone node outside of structures, then a better name for it might be the Error Collector Output Tunnel.
- The behaviour of the Error Collector Node would be unaffected by Automatic Error Handling being enabled or disabled in that VI.
- Using Error Collector Nodes would benefit programmers in the following ways:
- Would reduce the amount of "click-work" that programmers currently need to do (the number of wire segments and Merge Error nodes that need to be created), while ensuring that all unhandled errors are captured.
- Would reduce the amount of block diagram "clutter". This "clutter" is apparent in the third screenshot, which shows many criss-crossing error and DAQmx wires.
- Would decrease the size on disk of VIs thanks to fewer block diagram items needing to be represented in the VI file. This would help towards making git repositories a little bit smaller, and loading VIs into memory a little bit quicker.
- Informally, using Error Collector Nodes would sit in-between the strictness of manually wiring all error outputs, and the looseness of relying solely on Automatic Error Handling. The error handling gold-standard would remain manually wiring all error outputs, but using Error Collector Nodes might be "good enough" in many situations, if used judiciously.
