Time-consuming to customize the Quick Drop Palette.
So, I tried a prototype plug-in VI to think a way to easily register. (Add Shortcut.vi attached)
There is a problem in how to identify the registered name of the function palette for this VI.
I do not support the object of all.
But, I want you to try and they work once.
Can then be used by storing in this folder.
\ LabVIEW 2013 \ resource \ dialog \ QuickDrop \ plugins \
Note: VI This rewrites the LabVIEW.ini. Please use it to back up
What do you think?
