Dataflow_G
The 'key' input of the IPE's Map Get / Replace Value node should be required
Status: Declined
Filed as bug 1105765.
The key input of the Map Get / Replace Value node of an In Place Element structure is not a required input. This can lead to bugs, where a developer may have forgotten to wire the key. All other Map primitives require the key input.
The idea is to simply make the key a required input.
(The map isn't a required input either, but has a documented default. It should probably be required too though.)
3 Comments
AristosQueue (NI)
NI Employee (retired)
Christina_R
Status changed to: Declined
Christina Rogers
Principal Product Owner, LabVIEW R&D
wiebe@CARYA
Knight of NI
How about the default value?
https://forums.ni.com/t5/LabVIEW/In-place-Map-Access-returns-previous-Class-data-not-Class/m-p/40823...
Not sure if it should be required, but as it seems to be undefined, this should be documented somewhere.
Or is the returned undefined value a bug, and should it return a LabVIEW default (e.g. 0's and empty, like a default tunnel)?
