elset191
Use consistent increment and decrement
Status: Declined
Any idea that has received less than 8 kudos within 8 years after posting will be automatically declined.
Say I have a numeric control on the front panel whose value is 3.8.   If I put my cursor after the six and increment it (using the inc/dec buttons or the arrows) it goes to 3.9, 4, 5, 6.  It should go 3.9, 4, 4.1.
Tim Elsey
Certified LabVIEW Architect
5 Comments
elset191
Oops typo.  Put your cursor after the 8
Tim Elsey
elset191
This also happens at the front of the control.  If you place your cursor before 80 it goes to 90, 100, 200.  From 800 to 900, 1000, 2000, etc
Tim Elsey
JackDunaway
Trusted Enthusiast
The current behavior I think is desirable. To achieve your desired behavior, go to the Numeric properties, and uncheck "Hide Trailing Zeroes". This causes the "bump" actions to be 3.8, 3.9, 4.0, 4.1 and so forth.
elset191
I don't know if "desirable" is the term I would use.  Expected perhaps.  But not desirable.  And I don't think unchecking hide trailing zeroes would effect the second case I brought up in my replies
Message Edited by elset191 on 10-08-2009 12:49 PM
Tim Elsey
Darren
Proven Zealot
Status changed to: Declined
