When we create scripts in vision assistant we save it with "*.scr" extention. You have to open vision assistant everytime you want to open the script. I am suggesting double clicking the "*.scr" to open the script in vision assistant directly without the need for opening the software each time.If you open the file now you get an error message like this
If the extention is causing the problem or being the hurdle why not change it ?
