SteenSchmidt
Warning case in Error/No error case structure
Status: New
Hi.
I simply propose to add a Warning case in the automatically generated Error/No error case structure:
The inclusion of the Warning case could be optional, and maybe setup by right-clicking the case structure?
Cheers,
Steen
CLA, CTA, CLED & LabVIEW Champion
8 Comments
Gleichman
You're not asking for a change in the case structure, but a change in the error cluster. The internal control of the error cluster that set error/no error is a Boolean. Last time I checked there wasn't a tri-state Boolean Smiley Happy
David S.
NI Employee (retired)
I think -- and I'm not in R&D, so this isn't certain -- the reason that doesn't already exist is that there's no standard way to signal a warning. A lot of developers will use the condition of status = False and code != 0, but that isn't canon. NI would have to define a specific configuration of the cluster for warnings, and that would have a backward ripple efffect through old code.
David Staab, CLA
Staff Systems Engineer
SteenSchmidt
Trusted Enthusiast
Status = False and code != 0 is exactly the differentiator of the "Explain Error"/"Explain Warning" text when you right-click an error cluster indicator. Also look at this reply:
http://digital.ni.com/public.nsf/allkb/A5FBE856130518AF862570F4007D8761
Of course you could have several different ways to discern between warnings and errors, but the one above has been the accepted one among the LabVIEW programmers I know, in all the years I've been programming LabVIEW. I have never heard it disputed before, so I'd be quite interested if someone from NI R&D could tell us if this isn't the case?
Cheers,
Steen
AristosQueue (NI)
Steen has it correct. Status = False and code != 0 means warning. Used through out NI APIs, goes all the way back to the original creation of the error code cluster.
altenbach
Knight of NI
  1. Yes, it should by default behave exactly as it does now: two cases: error, no error.
  2. We can use the existing right click options "add case before|after, duplicate case, etc.) to generate the warning case.
  3. We should also have a menu option "Add case for every value" which would also simply add a warning case.
  4.  errorno error, warning.
  5. Since in point 1 we now have an under-determined situation, the "no error" case should be defined as "default" to retain the current behavior and should be labeled as follows:  errorno error (default).
  6. We should be free to assign the default to the error case in order to handle warning and errors specially in one case: error(default)no error.
dthor
Would it be a good idea to combine this idea with the principal behind this one? (http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Error-code-case-selector/idi-p/967725) For the record, I don't like the right-click-to-choose-input-method that the Idea I linked mentions.
The idea:
A case structure that, when an an error cluster is wired to the input, by default acts as it does now (2010SP1). However, a user would be able to right click and add a generic warning case. Then the user could add *another* case, and give it a specific error code for a warning or error. I think this would be relatively easy for NI to implement, and it could greatly reduce the need for nested case structures and unbundle nodes.
Here's the structure I imagine:
Case:                              Executes when:
no error (default)            Status == False and Code == 0
error (generic)                Status == True and Code != 0 (and not defined in other cases)
warning (generic)           Status == False and Code != 0 (and not defined in other cases)
Code 54                           Status == False and Code == 54
Code 3290                       Status == True and Code == 3290
Error Code 1                   Status == True and Code == 1
Warning Code 1             Status == False and Code == 1
Code 2                            Status == anything and Code = 2 (obviously this one would cause a broken VI if it was defined and "Error code 2" was also defined)
I think that this would cover all the basis very thoroughly, while still providing the simple Error/No Error functionality of the original case structure.
Also, thanks to altenbach for the idea of color-coding my reply Smiley Wink
EDIT: formatting
Edit 2: Added "Code 2" case
SteenSchmidt
Trusted Enthusiast
Yes, I also thought about being able to specify specific error codes, I just didn't have a good suggestion how to keep it uncluttered. The current Error/No error, and possibly with an added Warning, case structure is so clean it would almost be a shame to ruin it. But the first thing that almost always happen inside the Error case is a nested case selecting on "code". But be very careful about the implementation if you go for specific codes - sometimes less is more Smiley Happy
Cheers,
Steen
Darin.K
Trusted Enthusiast
Cases like this with multiple AND'ed conditions led me to suggest Multiple Case Selectors.
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-Multiple-Case-Selectors/idi-p/1301780
This application is right in its wheelhouse.
