ouadji
When closing project or quitting LabVIEW, Abort VIs dialog should list the VIs
Status: Completed
In LabVIEW 2021, the abort warning dialog will inform you what top-level VIs are running.
  It would be very usefull to know which VIs are still running.
12 Comments
Enrico_Segre
ditto for "Quitting will abort all running VIs"
fabric
This would be a reasonable place for a button to actually abort all those running VIs, before one decides to either close or cancel.
Enrico_Segre
fabric
Enrico: Agreed, but sometimes my project is locked up and all I can do is close it through Explorer or Task Manager... There are other tricks to close running VIs but most of us want something better out of the box!
Enrico_Segre
It happens to me too (for instance call to DLL hanging, including into that the "infamous USB-serial non-timing out dongles"). That however is out of the scope of this idea imho, and already mentioned elsewhere, like e.g.
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Need-a-Way-to-Exit-LabVIEW-Code-if-a-MODAL-Window-is/i...
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Abort-all-VIs-Button-in-Taskbar-Modal-Windows-Problem/...
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Abort-All-VIs-in-Project/idi-p/1818849
TaKend
If you want us to use the Actor framework or anything like it this is a must !!
JackDunaway
Trusted Enthusiast
Great idea! I would use this.
Rickard
I would like this list of "still running VIs" to be clickable so that the frontpanel of the VI is opened when you click on the name!
Christina_R
Status changed to: In Development
Christina Rogers
Principal Product Owner, LabVIEW R&D
ouadji
Trusted Enthusiast
Good news !
One more time patience was rewarded. 😊
