Problem: When developing or inheriting a large code base it is helpful to know which VI has Automatic Error Handling (AEH) enabled and which has it disabled. Currently, the quickest way to get this information is to bring up the VI Properties window (pressing Ctrl + I) and navigate to the Execution page. This is tedious when done on large numbers of VIs.
Solution: LabVIEW should display whether AEH is enabled or disabled on the Block Diagram. For example, a grey triangle located in the bottom-right corner of the block diagram window could indicate that AEH is disabled, and an "error green" triangle could indicate that AEH is enabled, as seen in the screenshots below. This display method is just a suggestion - professional UX designers may well find a better method. I would be happy with any indication method that I could at a glance see on the block diagram window.
Idea expansion:
