Cory_K
XYZ Graph
Status: Declined
Functionality already in LabVIEW.
I recently had to graph some 3D data, and found it more trouble than anticipated.
It would be great if there was a graph similar to the XY graph, but for 3D.
Instead of clustering just a 1D x-array and a 1D y-array, you could cluster a 1D z-array as well.
Then send the whole cluster to the XYZ graph.
Or 3 inputs, 1D arrays each would work.
It is difficult manipulating the data for the current required inputs of:
- 1D x array
- 1D y array
- 2D z matrix
Cory K
2 Comments
altenbach
Knight of NI
Look for the 3D line graph (or 3D curve graph in older versions).
It takes 1D arrays of x, y, and z.
(The surface graph is not suitable for your data).
G-Money
NI Employee (retired)
Status changed to: Declined
