Yamaeda
automatic panel position
Status: Declined
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
It'd be quite helpful if VI's could be set the Front panel position attribute.
For the 114th time, i just searched for something, scanned through the results and after a small fix compiled the program and deployed it. 2 Popup Panels dont work since they've moved and now show the input cluster ...
Either all Panels should be set to pos 0,0 at runtime, or be configurable as a run time pos.
/Y
Qestit Systems
Certified-LabVIEW-Developer
5 Comments
crossrulz
Knight of NI
You mean like this?
GCentral
Thoric
Trusted Enthusiast
@crossrulz: I also do that (I have a brat VI for it) when I need it, but I often think this would a be a great option for the VI Properties. We can set a multitude of other front panel properties from the VI Properties interface but not pane origin(s). This isn't such a bad idea, one which could perhaps be easily implemented.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Yamaeda
Proven Zealot
Yes, Xrules, that functionality should be integrated in the panels. When it happens it's a typical effect of e.g. looking through a "List all instances" of a type def or similar, in which case it moves a panel to show the type def. That's logical, but i'd assume it's extremely rare that's the position people want on the panel afterwards ...
It also seems like a cumbersome solution to add to all VI's on the off chance you search through this one ...
/Y
Qestit Systems
JÞB
Knight of NI
Sounds like a perfect case for a pre-build action.  Or, in other words, there is nothing to prevent you from doing this:
Watch uot for where the quotes are around the word "Default" in the cases.  "Default" is a string in the enumerated FP.Behavior type that we don't want the Default case behavior for.
"Should be" isn't "Is" -Jay
Darren
Proven Zealot
Status changed to: Declined
