QFang
graph/chart axis: "swap side" at run-time
Status: Declined
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
Currently, if for some reason you wish to move e.g. the x-axis of a graph to run along the top of the graph display, you have to do this at edit-time by right-clicking the (x-)axis and selecting "Swap Sides".  I have not found any property or invoke node to do this at run-time.
Instead, I have to duplicate a scale (at edit time), move one using "Swap sides", then in the program I need to programamtically track and control which one is visible at any given time.  Since the graph area properly resizes/moves as the scale(s) move in and out of visibility, I see no reason for why the "swap sides" functionality can't be a boolean property accessible at run-time? (But then again, there are a lot of things I don't see, especially on the back-end of the LabVIEW environment...)
As a side note, it seems like you can't even swap sides at edit times for a chart.
This idea is related to this idea:
Allow axis swap for Waveform charts graphs and intensity charts
QFang
CLD LabVIEW 7.1 to 2016
3 Comments
garrettmarsh
What version of LabVIEW? Regarding your last comment, I was able to swap sides for the chart in edit-time in LV 2013, so I'm wondering what behavior you saw. I did notice that you cannot duplicate the x scale however.
QFang
I went to double check my last coment on the chart and swapping sides, I see now that I do have that option at edit time for charts as well.  I'm sorry, I must have missed it when I was writing the idea.. Good thing that was a side note and not really the meat of the idea. 🙂  And we still use LV 2013 SP1.
QFang
Darren
Proven Zealot
Status changed to: Declined
