Here's another one. It has to be duplicate (at times it is so anoying), I can't find it though. If it is, please someone explain to me how to better find these duplicates.
Let's say you are editing your program. So you work in your project directory. Insert VI, Open, etc all start where you have been working recently.
Now you run your program, and select a path for your file (not a VI). You want these files to go somewhere else. You need to browse.
Then you start editting again. You have to browse all the way back to your project.
Then you start testing again. You have to browse all the way back to your data folder.
Etc.
I know. I can work around it. Create short cuts or something.
How about keeping a current path for edit time, and one for running time?
Wiebe.
