I would like to see a setting on an lvlib or lvclass that would prevent private and/or protected items from showing up in the VI hierarchy.
In a .lvlib or .lvclass we can set different scopes on items, but why not add a property to define (on lvlib/lvclass level) which scopes that should be visible in the hierarchy view? The items listed as private in a lvlib (or lvclass), are mostly not necessary to see in the hierarchy window as these are internal anyway (and are not intended to be used or seen by the end user).
This change would mean that large scale projects could look much cleaner in the hierarchy window, and that the relationship between reuse components gets much clearer.
To make this work for older projects, I would also like the end user to be able to filter out private/protected items directly from the hierarchy window, as we today can filter out vi.lib, globals or controls. Turning on private view would still not reveal the items set as not-visible in the lvlib/lvclass, as this was defined by the developer.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
