Save time and cleaner code by supporting a commonly used operation in test sequences. The In range and coerce would have
a mode to specify absolute (current operation) or relative mode where you wire a Center Value and Range instead of Upper Limit and Lower Limit.
Upper Limit=Center Value + Range
Lower Limit = Center Value - Range
Trivial to do but used commonly enough to be annoying to have to do that.
