User | Kudos |
12 | |
11 | |
11 | |
6 | |
5 |
When you have a project explorer populated by many classes, it takes many clicks to find and get to the class node in the project.
What I frequently do is to create a class object (or control/indicator) from a class wire then right click >> Show Class Library...
But this step adds an unnecessary object to the BD.
What I want is the same "Show Class Library" shortcut menu from WIRE, VI Connector Pane, and Unbundle node so I can quickly access to the class library in the project tree.
