Aesthetic issue: thick wires connected to Select inputs show as ugly corners behind the triangle icon, probably a result of the underlying connector pattern.This does not happen for other triangular blocks, at least not up to a reasonable wire thickness (to make a wire thicker, just make a N-dim array of something).
