For subpanels a method is used to insert or remove a VI. But when inserting or removing VIs into subpanels programatically, such as poping the VI out of the panel so that it is in its own window, there isn't a way to know if the subpanel has a VI loaded in it.
IDEA: Have a boolean property node for subpanels that returns if the subpanel has a VI loaded.
