The idea is to be able to replace wires running across a case structure with terminals that take the connection on the left side and connect it to the right side. I would think the left side should allow a through wire for reading variables, but the right side should not, as then the jumping structure wouldn't really be needed. This is something that would be specific then to that case or entry in the structure, and not the structure itself.
Any idea that has received less than 9 kudos within 9 years after posting will be automatically declined.
