labview installer
I am trying to run a project on another laptop which does not have labview. As you can see in the attached pic, I am using a reference of a vi, named "user entry" so that the front panel of this vi shows up .The reference points to existing directory from where the main vi is running.
When I run the installer and application on another laptop ,it gives me error as it can not find the "user entry" vi. How can I resolve this?
Any help appreciated
(840 Views)
The application builder cannot detect dynamically called VIs.  Therefore you need to tell the application builder to include it.  In the build specification for the executable, you need to put the "user entry.vi" in the "Allways Include" in the "Source Files" category.
GCentral
(824 Views)
Thanks for your reply. I appreciate.The project file column is greyed out.I could only put the startup file .after that it does not give me any option of choosing any other file.
Can you please help?
(791 Views)
Is that other VI even part of the project?
(781 Views)
when I click on "Find project item" after right clicking on the project name, it shows me the vi in the list
(771 Views)
Accepted by maccapple
@maccapple wrote:
Screenshot%202024-01-16%20081946
Your use of current VI path in an executable is incorrect. See here. Use Application Directory instead!
(Why are there so many wire bends???)
(765 Views)
You nailed it. Thanks.Tried with Application builder and is working. I was kind of aware hat it was not accepting the proper path  when I saw the error pointing to some different long file path for this VI. But was not knowing "Application Directory" can do the job.
(744 Views)
