NI Package Management Idea Exchange
Vaaben
Automatically install dependend Ni.com packages / feed together with own developed SW on fresh install
Status: Duplicate
Marking this as a duplicate of the idea that was moved from the Additional NI Software Idea Exchange.
What: installing a package on a newly installed machine where only NIPM has been installed. Dependencies to e.g. DAQmx Runtime and Labview Runtime
The problem: the installation will fail as NI Package Manager does not know the feed locations for the dependent packages. If these packages had been installed previous and uninstalled, then the feeds would be known and the installation could pass.
Proposed solution: Whenever a package requires NI products as dependencies, the Package Manager should automatically search / add the feeds from NI.com and install them
CLA, Teststand and advanced SQL
4 Comments
APena
Status changed to: Development Started
APena
Status changed to: Duplicate
CL_eisenwr
APena,
This idea is a duplicate of Automatically install NI dependencies from NI Package Manager, correct?
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
Vaaben
Currect - it is indeed a duplicate of that one - did not see it as it was located in another, unrelated idea exchange
