NI Package Management Idea Exchange
cbutcher
Install multiple .nipkg files together via GUI
Status: New
I'd like to be able to select a collection of nipkg files in e.g. Windows Explorer and use NIPM to install them in the correct order based on their interdependencies.
If I create a local feed and add that, then NIPM will allow this via selection in the Packages tab.
However, there doesn't seem to be a method to select multiple files that are not in a feed using a GUI (Windows Explorer or NIPM etc).
VIPM has an "Open Package File(s)" menu item that fills this role.
I think (although I didn't test, because I didn't consider this when I was running into this issue) that using "nipkg.exe install A.nipkg B.nipkg C.nipkg" would work for this, so there is a workaround. I just didn't consider it earlier...
GCentral
1 Comment
CL_eisenwr
I have used the nipkg.exe command line to do this and it does work as desired. You may want to look into the NIPM API as well as it does have VIs to install packages.
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
