DIAdem Idea Exchange
MMargaryan
Add Command Similar to schememeasstop() in NI DIAdem.
Status: New
After thoroughly reviewing the DIAdem help documentation, it seems there isn't a built-in command, like schememeasstop(), to programmatically stop measurements.
The objective is to automate at least two consecutive DAC measurements in NI DIAdem. While the first DAC measurement can be started and stopped using digital inputs, the current process still requires manual intervention. Specifically, the operator must press the "Stop Measurement" button on the DIAdem toolbar to end the first measurement before the second can be started.
