DIAdem Idea Exchange
JuliaDawkins
Add programmatic "copy" curve for VIEW
Status: Completed
Hello Julia,
Your request is now available in DIAdem 2021
Call View.ActiveSheet.ActiveArea.DisplayObj.Curves2D.Copy(1,"NewCurve",0)
Greetings
Walter
The user interface allows you to copy a curve in VIEW, but not the programming methods (like exist in REPORT).  I'd like to be able to "copy" a curve just like I can in REPORT.
4 Comments
Brad_Turpin
Trusted Enthusiast
Hi All,
I heartily support this idea!  There are two many curve properties, even in VIEW, to try to keep track of all of them and set them after creating a new curve.  Copying a curve would be very valuable in VIEW.
Brad Turpin
Senior Technical Support Engineer
TomOrr0W
@Brad_Turpin If you support the idea, you should kudos it.
The idea itself sounds logical, although I don't personally use DIAdem, so I will add a kudos as well.
Walter_Rick
NI Employee (retired)
Status changed to: Under Consideration
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions.
Greetings
Walter
Walter_Rick
Status changed to: Completed
Hello Julia,
Greetings
Walter
