DIAdem Idea Exchange
JuliaDawkins
Allow vertical tabs in SUD control TabPageCtrl
Status: Under Consideration
OK, this is an argument. Your requestis included in feature planning discussions for future DIAdem versions.
Greetings
Walter
I'd like an option for the tabs on the SUD dialog control, TabPageCtrl, to allow vertical placement, so the tabs would be on the left (or right) side of the tab control.
3 Comments
Walter_Rick
NI Employee (retired)
Hi Julia,
Thank you for your request. It is not exactly the same what you are requiring, but did you see the new SUD control "TaskPanel"? Maybe this is an option, too.
Greetings
Walter
JuliaDawkins
I did see that and it looks great, and I can sort of accomplish what I'd like with a combination of a TaskPanel and a TabPageCtrl with invisible tabs.  However, for space, I'd really prefer something like the attached image, where the text could also be vertical, though I'd put the tabs on the left.
Walter_Rick
Status changed to: Under Consideration
Greetings
Walter
